Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: Installing P trap for the first time..chrome or plastic?
    DIY Senior Member Andrew21's Avatar
    Jun 2006
    New York
    Default Installing P trap for the first time..chrome or plastic?
    Hey all,
    Just got my undermount sink in and now I need to hook everything up to the sink (faucet, p trap, etc). This is the first time I will ever do something like this and I'm not that clueless but somewhat lost.
    Should I use the chrome or the plastic piping? I would like a nice look under the sink. I know, I know, nobody really looks under there but I would gather it would look nice. If the plastic is the best and easiest way to do it, I'll go with that.
    Now the drain pipe is coming out 9 inches. WOuld I have to cut this? If putting in the chrome pipe, do I need to solder the connections? Thanks!
    Under a cabinet, I don't think appearance is an issue. Plastic probably has an edge in longevity...as in foever, whereas a brass trap will corrode ...eventually.... A brass, or chrome plated, probably has a higher success rate of not leaking at initial install. Plastic can sometimes cause a problem, as you can only tighten the nuts so tight. I usually replace the nylon gaskets with rubber ones, coating them lightly with plumbers grease. These seem to seal up better.
    If you are in MA, or some other states, you will be required to solder the trap arm to your waste stub. If your code allows it, I would cut that stub closer to the wall, solder on a slip joint trap adapter ( sometimes called a Desanko fitting).
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    short of using a rubber fernco which would be savage, a desanko or trap adaptor fitting will have to soldered on.
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    And it's going to take some considerable amount of heat to solder to that copper pipe. Just letting you know...
    Jun 2006
    New York
    Quote Originally Posted by nhmaster View Post
    What is a desanko adapter? Is that a copper fitting that when I solder it on, there's a thread at the end? I went to Lowes to get some parts but I didn't know 2 things.
    1. There are different sizes of pipes, 1 1/2, and 1 1/4.
    2. I took out a strainer and started to use the parts to put everything together in the aisle! LOL. As long as I know what to buy, I'll be good. But the last thing is that adapter.
    Dec 2007
    Do you know how to sweat copper pipe?
    Jun 2006
    New York
    Quote Originally Posted by Redwood View Post
    Yup! Thats not a problem.
    Dec 2007
    This would be the ticket if that is a 1 1/2" pipe. Measure the O.D.
    http://doitbest.com/Copper+Unions-El...sku-431063.dib
    Jun 2006
    New York
    Sweet! Thanks! Let me see if its across the street at HD...i doubt it though.. will report back
    btw, what does DWV mean?
    Dec 2007
    Drain waste vent.
    Jun 2006
    New York
    thanks. Of course they didn't have it at HD. Its the worst there. Fittings and stuff all over the place. Time to take a trip to Lowes or the local supply store.
    They did have it in the PVC section though. But I wouldn't know how to connect it to the copper if I did get the piece.
    Thanks Redwood!
    Dec 2007
    PVC is tough to solder!
    The route you're going is better.
    Jun 2006
    New York
    I know! LOL. anyway, gotta run to the other store. Will keep you posted.
    Jun 2006
    New York
    Ok, i'm back. Was tied up doing other things but here's my plan. Hopefully I'm doing this correct.
    I'm going to cut the waste pipe closer to the wall to install a 45 degree angle street elbow and then put on the trap adapter fitting as pictured before. Then sweat the fittings on and connect the rest. The sink drain is not aligned behind the waste pipe. Sorry for the angled shot. Here's what I'm up to now..
    I just took a picture of this to see if the fittings fit...
    Dec 2007
    Thats one cheapo junko looking basket strainer...
    Well how did the pipes line up?
