Mould in sewer clean out casing
dharrison
We have had mould in our basement near the sewer clean-out for the last 2 summers, this summer being worse than last (we had a wet summer this year). This is a 16 year old house with partly finished basement. The sewer clean-out is located inside an 18 inch square cavity that is cut into the basement floor and the end of the pipe is about 2-3 inches below floor level. The cap on the clean-out is tight and we have had no sewer backups and no reason to suspect anything is wrong with the clean-out piping itself. The cavity is open to the bare ground beneath and has some gravel fill on top (up to the level of the clean-out) and is covered by some plywood. We are assuming the exposure to the bare ground is the issue. My solution is to pull out the gravel and use concrete to create a seal from the bare ground level to about 2-3 inches from the top of the clean-out. Wondering if there are any comments on this or other suggestions?
Master Plumber Mark
www.weilhammerplumbing.com
good molds and bad molds
just becasue it is mold does not mean it is nasty.
their are only a few types of mold that are bad for you
and their are dozens of molds that exist in our homes and crawl spaces that are natrual ..
the best solutioin would be to go buy a gallon of bleach
and every 6 months or so pour some around that area....
dharrison
thanks MP mark
Thanks Master Plumber Mark - lets assume it is bad mould, any comments on the proposed solution?
Redwood
Then you would have to take appropriate remediation measures...
Find out what you have...
