bamatbucket
- Messages
- 3
- Reaction score
- 0
- Points
- 0
I am doing a complete replacement of my existing 4" cast iron drain system in my old house to correct some existing problems and later add a bathroom and kitchen in the basement. I have done extensive research through plumbing books and internet forums and am confident that I can so this correctly, but I read something in one of the books that raised a question. Should I use a
3" wc arm for the new low-volume Toto toilets I plan to install instead of the 4" size I was planning to use so that sufficient velocity is maintained to insure that the solids move with the liquids? The existing 4" wc arm is close to the vertical stack and the proposed basement wc would drain into a new horizontal branch. The plumbing books encourage use of pipe sizes larger than minimum when possible. I know 3" is minimun for a wc arm, but I assumed 4" would be better.
