Results 1 to 2 of 2
Thread: Foot Valve Size
    DIY Junior Member cr506's Avatar
    Jul 2012
    TX
    Default Foot Valve Size
    I had a 2" well drilled. The driller put a pvc cap on it since I was going to finish it out later myself. The cap was on for the last few months. I bought the packer assembly, foot valve, SRA's etc. I was told I needed a 1 1/4" foot valve. When I went to drop the piping into the well the foot valve would not go. It was too big. Is this the correct size foot valve for a 2" well or could the cap possibly have had some effect on the pipe?
    The well piping is lettered with green lettering & says 2" jet pipe, or something similar to that wording.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    You have to have a special footvalve that will fit in 2" casing, not all 1-1/4" footvalves will go.
    If you have a Goulds jet (common) then it uses a 1" footvalve. Sta-Rite uses 1-1/4" footvalves.
    Whatever you do make sure you use a brass jet. Cast iron will eat out in some water conditions as it will be the only metal in the plastic well.
    Good luck.
  1. Proper resin tank size for 2 cubic foot softener?
    By FleckLander in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-22-2012, 05:50 PM
  2. Foot valve
    By solafide in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-09-2010, 06:33 PM
  3. bad foot valve?
    By dotsnider in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-16-2008, 06:54 AM
  4. Bad foot valve
    By Guest in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-08-2008, 08:26 AM
  5. how do I get to my foot valve?
    By Mick in forum Irrigation / Sprinkler Forum
    Last Post: 05-19-2008, 11:09 AM
