Thread: Kickspace Heaters (Beacon Morris)
    DIY Junior Member CTWeekendWarrior's Avatar
    Jul 2008
    Enfield, CT
    Default Kickspace Heaters (Beacon Morris)
    I'm in the process of adding a bathroom, and wall space for baseboard heat is scarce in my design. I am considering using a kickspace heater, such as the Beacon/Morris Twin-Flo III installed below the vanity. Does anyone have any experiences/input on these units? The bathroom has an approximate volume of 500 cu ft. Is one unit (5600 BTU) enough to heat this space? Any info much appreciated!
    Product website: http://www.beacon-morris.com/html/ki...t_twin_flo.asp
    Licensed Plumbing and heating contractor for 25 years Radster's Avatar
    Sep 2008
    Ontario Canada
    Hey CTWW,
    I don't know if you still need answer for this as you seem to have posted it in July. But for what it is worth.....heatloss calc that is the key word here. The 5600 btu would be at 180* water so would have to say that it may do it but like I said Heat Calc is the only way to know for sure. We have installed a few of these types of units and if they are installed properly and sized right......no problems.
    Jul 2008
    S. Maine
    The k41 is more than enough to heat a bathroom that size.
    Sorry to resurect this one - but did you go with the one you spec'd out above?
    How noisy is it?
    We're thinking of putting a kickspace in as part of a bathroom remodel too, but the bathroom is right connected to the master bedroom and we usually sleep with the bathroom door open. I'm a bit concerned about how much noise the fan might make at night as it cycles on and off with the heat.
    Any brands / models that anyone has found are particularly quiet?
