Sounds like you have a good understanding of wastes & vents. If you can,it would be better to cut the 3" 90 off at the downstream side, Put in a 3" "side inlet" 90 (has a 2" cup in the side) Also called a side inlet closet bend.Bring your riser back up for the WC , pipe your lavy and shower off the 2" making sure to wet vent the group off the lavy. More work but worth the trouble in the long run. Good Luck !
