Results 1 to 2 of 2
Thread: Should I install a cleanout for new toilet drain installation?
    DIY Junior Member redgreen's Avatar
    May 2008
    Canada
    Default Should I install a cleanout for new toilet drain installation?
    The drain coming from the main floor toilet comes through the basement ceiling and I was going to just add a 90, then a 5 foot horizontal run before it will enter a san-tee that I will add to an existing vertical stack which goes to a second story bath.
    Instead of the 90 can I install a wye on it's back, add a 45 to connect the toilet, the downstream of the wye will connect to my 5 foot run and on the other end of the wye I was going to extend it a foot longer and add a cleanout. Is adding a cleanout as I described a good idea and is it allowed as I described?
    Thanks.
    Default piping
    NOTHING about what you describe is a good idea, nor is it legal or proper. Or rather maybe the cleanout is the only part of it that MIGHT be a good idea.
