Results 1 to 5 of 5
Thread: Using ROMEX® to feed subpanel, do I have to derate from Table 310.15(B)(6)
    Default Using ROMEX® to feed subpanel, do I have to derate from Table 310.15(B)(6)
    I want to put a subpanel in the garage. According to Table 310.15(B)(6), I would need #4 Copper for a 100amp subpanel. Is this table for individual conductors in conduit or can you use ROMEX® to feed the subpanel at 100amp? The reason I ask is I read that when using ROMEX® you had to derate the THHN in ROMEX® to the 60*C rating.
    Mike
    Further research has indicated that I do need to derate when using NM.
    Jun 2007
    North Carolina
    Do just a bit more research and you will see that Table 310.16 must be used also
    Jun 2007
    NY State, USA
    You are not "derating" anything. NM cable simply must use the 60 deg C column.
    IF you did need to derate the cable you would do so from the actual insulation temperature column which is 90 deg C.
    Electrician Chris75's Avatar
    Aug 2007
    Litchfield, CT
    Quote Originally Posted by Mr_Magoo View Post
    Mike
    As already mentioned, you cannot use table 310.15(B)(6).
  1. ROMEX®/cable color changes
    By taz110 in forum Electrical Forum discussion & Blog
    Last Post: 09-08-2013, 10:28 AM
  2. ROMEX® to dryer outlet - insulated ground?
    By Plumbob in forum Electrical Forum discussion & Blog
    Last Post: 12-23-2009, 05:35 PM
  3. Adding Circuits using ROMEX® vs. AC cable
    By mrhoades in forum Electrical Forum discussion & Blog
    Last Post: 02-14-2009, 08:44 AM
  4. table saw question
    By shluffer in forum Remodel Forum & Blog
    Last Post: 05-23-2008, 07:58 AM
  5. Table Lamp
    By Fudog in forum Electrical Forum discussion & Blog
    Last Post: 01-01-2008, 06:24 AM
