Poisson Cru
I'm in an upper condo of a two unit condo building in Santa Monica, California. The owner below, (which hates me and doesn't speak to me), notified me by a third party that our shower is leaking and damaging the ceiling of her unit and that the lack of repairs by a licensed contractor is compromising the integrity of the structure ¦and that I need to stop use of the shower immediately A photo was attached showing the drain and plywood subfloor taken from an access door in this neighbors unit as below. I assume the black marks are areas of dampness. Does this photo help?
The tiled steam shower was constructed in 1994. The neighbor complained 8 months earlier of the same problem. I spent a day cleaning the tiles, and re-caulking all the corners, the curb, and the glass shower door. I didn't hear anything from the neighbor for 8 months and assumed that all was ok. At the time I noticed that the slope on the curb was backwards, water pooled on the tile floor next to the drain flange, the 5x5 tiles have settled a small amount in regards to the drain flange, and the grout in some areas is worn. I have not yet inspected the weep holes to determine blockage. Here is a photo:
One of my problems is I don't have access to the inspection door underneath, and need to have a licensed ?? to make an appointment with the neighbor to inspect and evaluate. I don't know how bad the problem is and exactly where the problem is: If it is a problem with the curb or with the shower pan, or ??
The question I have is who do I need to employ? What type of professional should I call?
Should I first start off with a home inspector who can take photos and document the problem? Or should I start off with a plumber to make a leak test? Or should I contact a tile & grout expert to renew the grout, reset the tile on the curb to slope and seal, or should I start off with a general contractor and tell him to tear and repair?
