Thread: Tust around tub flange/drain
    Default Tust around tub flange/drain
    I have a standard tub but there is a growing rust spot in the tub right by the chrome drain flange (not on the flange itself). I want to take out the flange, sand down the rust, seal with enamel epoxy, and then re-install the flange. I have no access to under the tub. Can this be done? I've installed drains in sinks before but that was always from underneath. Can I remove the drain flange without access to under the tub? How? Can I re-install without creating a leak - will plumber's putty seal it? Will sanding down and coating the rust work to stop (or at least slow down) the growing rust in the tub?
    Dec 2007
    Sounds like a steel tub close to the end of it's life...
    That would have Do Not Disturb written all over it unless you are ready to remodel now.
    Default tub
    If it is a failing cast iron tub, (and it would be rare if it were), and the drain plug is not frozen in place because of a poor installation, you may be able to do it. But if it is a steel tub, when you remove the plug you may find the entire area underneath it has rusted away and there is no way to repair it.
