Patchesj
- Messages
- 8
- Reaction score
- 0
- Points
- 0
I purchased 3 Toto Aquia I's for our new house. The plumber installed everything, but now we are failing our plumbing inspection and the plumber tells me the toilets aren't going to work. I'm not a plumber, and I'm not following exactly what is wrong. Basically he says they plug the sewer connection (septic in this case) and then flood the drains. They have this odd looking vacuum tube device they stick down the toilet to determine if the toilets are holding water properly in the trapway. Ours are not... He says he can remove the toilets, insert plugs, and the tests pass. Has anyone else run into this before? Could this be an installation issue?
