Results 1 to 9 of 9
Thread: Code Question
    Default Code Question
    Does a washing machine need a dedicated circuit?
    Thanks again
    Kind of a trick question.
    The laundry room needs one. The dryer can also be plugged into it.
    Can another outlet in the same room be on it????
    I think I found the answer:
    NEC 220-4 (c) Laundry Branch Circuits-Dwelling Unit. In addition to the number of branch circuits determined in accordance with (a) and (b) above, at least one additional 20-ampere branch circuit shall be provided to supply the laundry receptacle outlet(s) required by Section 210-52(f). This circuit shall have no other outlets.
    Jun 2007
    North Carolina
    Quote Originally Posted by jaxbldginspector View Post
    Are you still on the 1996 code cycle?
    What you have quoted is from that cycle!
    Default washer
    And, as an aside, here, when there is an electric dryer, the washer outlet is a single device receptacle so nothing except the washer can be plugged into it.
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Do you have anything in writing to back up that statement?
    Yes I am A Pirate-Jimmy Buffett
    Jun 2007
    NY State, USA
    I agree. If that is an actual code there must be a written amendment to back it up.
    That certainly is not an NEC requirement.
    Default outlet
    It is just the way the electicians do it, and they do the same with other outlets such as a freezer or garage wall air conditioner that should not be connected to a GFCI so that no one can plug an extension cord into the same outlet and not be GFCI protected while using it.
    Electrician Johnny C's Avatar
    Oct 2008
    Mass. & now Virginia Beach, VA
    Default Circuit for washing machine
    According to the NEC, it allows more than one receptacle outlet to be installed on the 20-ampere laundry branch-circuit. If you have a gas dryer, both the gas dryer and washing machine can be plugged into the same 20-ampere circuit, however, if the UL Labeling and Listing of the products specify that they must be on their own 20-ampere branch circuit, then 110-3(B) takes precedent.
