Results 1 to 8 of 8
Thread: best "roto Zip"
    Default best "roto Zip"
    What is the best "roto zip" type tool to buy. I know there are several different companies that now make them. What is the best overall tool to buy. Thanks, Pete
    I like the Rotozip brand. It also has a grinding wheel attachment.
    I also have a RotoZip brand which I use a lot. But, I also have a Fein Multimaster which is also great, does a lot without all the dirt of the RotoZip. They both can do things the other can't, so both are very useful.
    thank you gents!
    In the Trades AZ Contractor's Avatar
    Apr 2007
    Phoenix, AZ
    I have the cordless RotoZip. It works well for smaller applications.
    I also have the corded Dewalt hole saw. I use it less but it also works well.
    Default roto zip
    The bits and accessories are generic, so ANY device that spins them, such as a Dremel Tool will do the same job. The difference is in how the tool feels in your hand.
    DIY Member teamo's Avatar
    Jun 2005
    Massachusetts
    I have the rotozip as well as the dremel. They are two different tools. The dremel is only good for very small jobs. The Rotozip has a lot more power and can do heavier work such as grinding block and tile.
    There are a lot of small routers out there. Rotozip probably has a larger variety of add-on accessories. Check how many amps or watts the thing draws...larger numbers mean more power. See which one fits your hand best.
