Results 1 to 5 of 5
Thread: bleed valve leaking
    Default bleed valve leaking
    new runtal towle warmer bleed vale leaks w/30 psi air test
    do these radiators incorporate a float ball inside also, actuated by the water level?
    thanks any help would be appreciated
    Rita
    Jul 2008
    S. Maine
    Are you saying you put 30lbs of air on the system?
    30 psi in the loop befor connecting to manifold
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    You may have a vent with a hygroscopic disc and if so then yes, it will leak slightly on air pressure. If you have a float-type vent it will definitely leak with air pressure.
    Dec 2007
    After much research I found the answer in a copy of...
    "Common Sense" Written by Thomas Paine January 10, 1776
    The vent is designed to eliminate air from the system.
    Therefore it would be an entirely reasonable assumption that it would not contain the air pressure in the system during testing unless it was capped or otherwise prevented from doing its intended job.
