Bathtub drain & cleanout plate
sdjerry
San Antonio, TX.
This is basically two questions in one thread, so I'll get to it. I have attached a picture of the drain and the clean out plate in my bathtub. Basically I've only been able to take showers in this tub, never a bath. And that's because there's no sort of drain stopper with this, I've tried the cheap rubber stoppers but I can't find the right size and so water always gets through and it won't hold a bath. Is there any possible way I can replace this drain with a toe touch drain stopper myself? I'm thinking it's as simple as removing this old one and replacing it with a new one, but maybe I'm dreaming and it's best left to a plumber, you tell me.
Also where a lot of baths have the lever for a drain stopper mine just has a clean out, and as you can see there is a clean out plate. The plate is old and unattractive, any way I can simply buy a replacement plate that looks newer and better and just replace it?
Thanks for your help in advance. :)
Redwood
You may be able to find a toe tap or, lift and turn that threads right into the existing drain. It looks like that is what was originally there.
Big box should had that and the overflow plate...
sdjerry
San Antonio, TX.
Thank you for responding Redwood.
I don't see any visible threads inside this drain, so would a lift & turn style stopper still work with this somehow?
Jimbo
San Diego, CA
In the pic, I definitely see threads in the center of the crossbar X. Those threads will usually be either 5/16" or 3/8". Those are the two common sizes of lift&turn or push pull stoppers you will find.
sdjerry
San Antonio, TX.
Thank you for pointing out the threads in the center of the hole as I did not notice them. This should be a fairly simple task then.
Regarding my clean out plate, forgive me if this sounds silly, but can that plate be opened without turning the water off? I mean if pop that thing open water isn't going to come gushing out of there will it? :)
Redwood
Nope, open it up it is connected to the drain.
If your tub was ever to clog that would be the access point.
