Results 1 to 3 of 3
Thread: Too much staining from iron in well water
    Default Too much staining from iron in well water
    Any recommendations on types/brands of system to inject a deionizing solution with my irrigation water?????????
    Previous member
    Jul 2005
    Riverview, Fl.
    We sell a chemical that is manufactured here in Florida that is mixed with water depending on your water's mineral make up that when injected with a chemical feed pump will sequester the iron and make it fall off instead of staining.
    bob...
    In the Trades Bob NH's Avatar
    Oct 2005
    New Hampshire
    Here is a link to managing iron and manganese in drinking water. Some of it may apply to your irrigation application.
    http://www.fs.fed.us/eng/pubs/html/9...308.html#Seque
    Sequestration is reported to work at iron concentrations up to 3 mg/liter.
    If you have a large area you could set up a settling tank (a pond), or an open-air sand filter to filter the water after it is oxidized. It would require re-pumping.
