I have a similar situation to another post- an old dishwasher installation rigged in across from the sink in a small kitchen. Old DW leaked, so now replacing with nice Bosch model. Old DW had flexible plastic drain hose coming from its connection to a 20" loop behind it, then connected to a rubber drain hose that ran down, through floor, and then horizontal in joist space in tall crawlspace, then up to disposal. No "air gap" at the sink. We often had back flow into the dishwasher if we forgot to run the disposal for awhile and did a lot of dishes in the sink before running the DW later. Got pretty gross, although if we quickly turned the dial to wash it would drain off (then we would stop it- beauty of turn dial controls)... it definitely exceeds the total drain length reccommended by Bosch: 92" or 102" depending on the model.. that includes the loop they say... One: regardless of code, will installing an air gap at the sink (it has the hole) do the trick; Two: from the other post it sounds like the manufacturer's max drain length is more advisory, but will two or three feet extra, including all the verticals and loops, mean it will not work right?; Three: if there is an air gap device at the sink do we still need the loop at the DW; and Four: could we just route the drain to a ABS waste line in the crawlspace coming from the clothes washer, right near where the DW drain line currently penetrates the floor.. and if so, then if so, will keeping the loop at the DW provide the needed air gap? The ABS is 1-1/2" and only has the clothes washer on it until it gets to the main sewer stack. No way to reroute drain through cabinets, and it would only add length. Thanks for any advice you may have.
