delturcious
About a month ago, my fiance and I moved into a new house that has a well pump from before city water was available on our street. From what I can tell, the pump has been disconnected for a period of months or years and no longer has pressure. I have an engineering background, but that doesn't involve pumps. All I know about pumps and wells is what I've read on this forum and a few other random places this evening. I'd like to be able to use the well for an irrigation system, washing our cars, and other outdoor things. Here's what I've been able to gather so far... maybe someone would be kind enough to educate this pump newbie on how to get the water flowing?
1. The pump ran (or at least makes noise) as soon as I plugged it in, but no water or air (that I could feel) came out.
2. There is a pressure gauge on top of the pump that read 0 PSI after being run for a few minutes.
3. There is a shutoff valve on the discharge side that appears to go to the house and is closed.
4. Between the pump and that valve is an ordinary spicket for a hose connection. This is what I opened to find no water/air coming out.
5. From what I've read, running a pump without water is BAD so I unplugged it after a few minutes.
After reading a bit here, I believe that I have an above ground jet pump that *hopefully* just needs to be primed. That, however, is not something I know how to do. It looks like I can either a) dump some water down the discharge line or b) look for a place on the pump somewhere to dump water before plugging it in again. I don't want to do any damage, but I'm hoping that it's a simple DIY fix. Is there a preferred method for priming? I can go take some photos tomorrow of the pump and piping since I'm sure there are a million different pump designs. Is there anything else that I should check before running the pump again? Thanks in advance for all your help!
