Thread: solder
    Default solder
    i have a full spool of solder thats been in the garage for i dont know how long.
    it is dutch boy and has the following markings:
    Sn 95% Sb 5% also says ASTM B-32.
    i also have a half spool of one that is oatey silver lead free solder but has no other markings.
    i am soldering some copper for water supply lines and want to make sure this is applicable.
    Soldered with No-Lead Solder
    Jul 2008
    S. Maine
    It's fine. Go ahead and use it.
    DIY Senior Member Wrex's Avatar
    Mar 2008
    New Jersey
    Just make sure that any solder that you do use doesn't say Pb on it which means lead.
    The solder you're using is a combination of 95% tin and 5% antimony solders also bearing silver exist however the SB SN mix is the most common.
    “It often requires more courage to dare to do right than to fear to do wrong.”
    Abraham Lincoln
    "To move ahead you need to believe in yourself...have conviction in your beliefs and the confidence to execute those beliefs.”
    Adlin Sinclair
    Default 95/5
    It is actually the other way around. Silver bearing solder is the most common. 95/5 is also available, but is not used as much as the regular stuff because it is less tolerant as far as heat is concerned.
