The valve may not be able to deliver the amount of water that rainshower head needs to give a good shower. The original Mixets, with a long internal mechanism, did have an optional clip to limit the rotation of the handle, but the later ones with the short stem, which is what you probably have did not have it so the handle could, and would, rotate 360 degrees. As for your no hot water problem, unless there is a problem with the valve in the wall, or it has the optional in wall valves, there should be no way for that to happen.
