Have you had it inspected yet?
I moved my rough-in in my basement about 10 feet. I've already rerun the new pvc and I'm about to pour the new concrete back into the trench I dug. Are there any things I should consider before pouring? I'm going to use cardboard around the toilet drain to create the space needed for the flange to fit. Can the concrete be poured right around the new drains? Do I need to replace the vapor barrier? Should I put gravel back into the holes here the drain isnt? should I replaced the wire that I cut out ( the trench is about 12 in wide)? Is there a specific type of concrete I should use? And finally,should the concrete be poured all at once?
yes, its been inspected.
Are you planning on bag mixing or having it delivered? Did you saw cut the existing slab? Where are you located (state would be close enough)?
-Sam Smith
Licensed Professional Geologist - AL, TN, KY
Also you have refilled the hole...
How have you compacted the earth?
I live in Maryland. I was going to mix bags. It's an area of about 12 feet long and 1 feet wide. Honestly, not a lot of dirt came out of the hole. It was about 4-5 inches of concrete and another 5-6 inches of gravel. I used a saw for some, but mostly a jack hammer.
You started out with approx. 4 inches of gravel, a vapor barrier to prevent water vapor and radon migration, and wire mesh to make the 3000 psi slab resistant to cracking.
I would but the soil back in excavation, compact (hand tamper), put the gravel back in, compact, put the vapor barrier back in, and use 5000 psi high early strength bag mix. If the sand is dry, you may need to wet it a bit to get good compaction. You want the grains to stick to each other; you can make a golf ball sized clump by hand to check. Use the 5000 psi bag mix because when you mix concrete in a wheelbarrow, you rarely achieve the rated strength. Try to resist the temptation to get the concrete too wet.
Unless you can tie the new wire to the old, I don't think your trench is wide enough to require replacement. If the existing concrete is sufficiently rough (like you'd get from using a demo hammer), the new concrete will key in and won't settle. If you have sections that are slick from top to bottom, consider roughing it up. I don't think it will be necessary to use rebar dowels, but I haven't seen it and I don't know how well the underlying fill will be compacted.
Someone is bound to come along and say this is overkill, but this is how I would do it.
-Sam Smith
Overkill is a good thing!
For compaction of earth I like to use water.
I soak until there is a puddle then poke it with a broomstick until the water disappears, repeat and repeat until its not soaking in anymore.
Then let is sit overnight and it is then about as compact as it can get.
Where the new concrete is meeting the old I use a concrete bonding agent.
http://www.google.com/search?hl=en&q...+bonding+agent
Thanks guys, edge is pretty jagged, so the new concrete should "key" into the old pretty well. I don't think I need new mesh because the tench is only 11 inches wide. I'll put the dirt and gravel back in and compact it. Is there a certain type of tape that I should use to replace the new plastic to old?
