bnk26
- Messages
- 27
- Reaction score
- 0
- Points
- 0
need some advice, been almost a year since I've been here for advice, and all the help I got then was phenomenal for a plumbing illiterate person. Anyway I hope I give all the pertinate info so someone can help me get this problem fixed. I live way up on a hill, causing little to no water pressure so as is in the case of a well, I have a water pump and a pressure tank, I put in a new pressure tank last sept. I had no problems until yesterday. suddenly there was air in the water. after noticing that, I went out to see what might be wrong. the water pump was running, and the pressure guage was stuck at 10 psi and the pump kept running with no increase in psi, so I turned the pump off, so not to burn out the pump.I then decided to check the the pressure in the tank, it was at 10 psi, it was a pre charged 35 psi tank. has the bladder burst? is it the pressure guage? pump? any help would be greatly appreciated
