Results 1 to 13 of 13
Thread: RE- Connecting 4 ABS to 4 steel, near tree roots.
    DIY Member lahabra's Avatar
    Dec 2007
    California
    Smile RE- Connecting 4 ABS to 4 steel, near tree roots.
    Tree roots have distorted a rubber hub and have grown into my sewer line.
    I have found and dug open the problem joint. Now I want to Replace the hub and wrap the joint with something to keep the roots away.
    I am Not willing to Internally re-line the pipes, replace the metal sewer main, Or kill the trees.
    How can I re-do this connection and prevent the tree roots from re-entering the sewer?
    In the Trades Master Plumber 101's Avatar
    Aug 2008
    Wisconsin
    Can you use 4" fernco couplings. Cut the bad section out splice a new piece in between. Is no hub cast iron?
    Dec 2007
    Something like this would be good.
    Dec 2007
    California
    Quote Originally Posted by Redwood View Post
    That is what the previous plumber used. The tree roots were able to pry it open and move the rubber out of place.
    Are you suggesting that the coupling was not properly installed and that's why the roots destroyed it? And, if the new coupling dose not leak the roots will not be attracted?
    I am thinking of going over the top and doing a super repair. I am planning to:
    1. Rub toilet ring wax on the ends of the pipe to fill any imperfections.
    2. Install a 4 Fernco rubber coupling over the wax.
    3. Wrap the joint with copper wire to inhibit roots.
    4. Wrap with 20 mill tape to seal.
    5. Coat it with copper sulfate.
    6. Seal again with more 20 mill.
    7. Add 200 cooper clad pennies into the back fill dirt.
    Roots seek water. If the thing wasn't tightened down properly OR if the ends weren't in line (distorting it) OR if the pipe wasn't clean when attached, there could be a leak. The tendrils are quite small, so any leak would leave enough space for it to grow in there.
    Dec 2007
    If water is leaking out of the pipe roots will enter it.
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    Sort of sounds like the mission bands were not the right ones for the job. That is why they make different bands for all types of materials and they should not be mixed.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Rubber Hub 4" Steel X 4" Abs Roots
    Forget All About All Those Copper Pennys And Wire Stuff And Wrapping With Mil. Tape
    All You Have To Do Is Install New Band Coupling And Take Some Rock Salt Pour Over And All Around Joint No Roots Will Grow Though Salt ! ! ! !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Dec 2007
    That should be good for the cast iron.
    Dec 2007
    California
    Dose anyone like or dislike my idea of using toilet ring wax?
    Aug 2007
    Default 4"abs X 4" Steel
    Important Note;
    Roots Grow THOUGH Wax Seals
    MACPLUMB 777
    E-MAIL
    Dec 2007
    It will probably help the mission coupling slide right off the pipe too!
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    You cuold use what we call is a hot pour, hot melted tar over the joints.
    This is old school I know but it worked for many decades.
