Results 1 to 10 of 10
Thread: I want to add a new toilet line to my septic
    Aug 2008
    Sanford, FL
    Default I want to add a new toilet line to my septic
    tank. The new line is coming from a 90 degree angle from the inlet pipe. Is it okay to just drill the side of the septic tank and insert the new line? The tank is currently used only by the kitchen.
    Thanks for any and all replies.
    Wayne
    Dec 2007
    Maybe... Maybe not... It depends on the configuration of the inlet baffle in the tank.
    Aug 2008
    Sanford, FL
    Default I understand the baffles, so if I drill into the side closest
    to the end where the inlet pipe attaches am I going to create any unforseen problems?
    Thanks,
    Wayne
    Dec 2007
    Does the baffle extend the width of the tank? Not all do!
    Master Plumber nhmaster's Avatar
    Jul 2008
    S. Maine
    Ralph's a nice touch. Who's got Ron Paul?
    Aug 2008
    Sanford, FL
    The tank is 40+ years old and made of concrete. So do I just open the access lid to check for how wide the baffle is?
    Thanks,
    Wayne
    Dec 2007
    You would need to open the end where the inlet baffle is. Any line cut into the tank would have to be on the right side of the baffle. If it is a small drawer type baffle the inlet would have to wye into the line.
    Dec 2007
    Quote Originally Posted by nhmaster View Post
    I thought he dropped out of the running...
    Plunger/TurdPuncher kingsotall's Avatar
    Aug 2008
    Flagstaff, AZ Sitting on an upside down 5 gallon bucket next to the GO 68HD
    Default Hey, you guys, stick
    to the subject at hand.
    Default tank
    The baffle is usually a cast in place "tube". You normally have to connect to the existing pipe before it enters the tank.
