Installing coupling/pipe/bend in a tight space
nc8861
North Carolina
I'm replacing a closet bend and a small section of 3" pipe going out to the main stack. My bend currently comes right up against a joist. So I don't really have much clearance on that end - and of course I don't have any clearance on the stack end. I have to cut the current stuff out, install a coupling, section of new pipe, then the bend (the bend has to come up in the same spot). So how do I get the same length/measurements in a space with no clearance? It's not like I can bend the coupling or pipe.
On another board it was suggested that I use a shielded coupling that tightens down with screws. I'd really like to avoid anything but ABS + cement, as I don't want my toilet "stuff" going through a non-cemented joint. Is there any magical way to do this?
Basement_Lurker
One who lurks
Victoria, BC
Is there enough 3" pipe coming out of the tee on the main stack for you to glue on a 45? You might be able to replace that closet bend with two 45s to make a connection to the flange.
