Results 1 to 6 of 6
Thread: Installing coupling/pipe/bend in a tight space
    Default Installing coupling/pipe/bend in a tight space
    I'm replacing a closet bend and a small section of 3" pipe going out to the main stack. My bend currently comes right up against a joist. So I don't really have much clearance on that end - and of course I don't have any clearance on the stack end. I have to cut the current stuff out, install a coupling, section of new pipe, then the bend (the bend has to come up in the same spot). So how do I get the same length/measurements in a space with no clearance? It's not like I can bend the coupling or pipe.
    On another board it was suggested that I use a shielded coupling that tightens down with screws. I'd really like to avoid anything but ABS + cement, as I don't want my toilet "stuff" going through a non-cemented joint. Is there any magical way to do this?
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Tight Space
    Yes Call A Plumber ! ! !
    MACPLUMB 777
    E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    At this point, I like the shielded coupling.
    Jul 2008
    S. Maine
    How about a repair coupling?
    In the Trades kordts's Avatar
    Oct 2005
    exurban Chicago
    Get a pipeshredder or rambit and cleanout the hub of the tee on the stack and then repipe.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Is there enough 3" pipe coming out of the tee on the main stack for you to glue on a 45? You might be able to replace that closet bend with two 45s to make a connection to the flange.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
