Results 1 to 9 of 9
Thread: Submersible loses volume and pressure
    Exclamation Submersible loses volume and pressure
    I have an 85' well with a 1/2hp submersible about 14 years old. Static water level about 25'. It has been great for doing my irrigation and domestic until this year.
    Now, it works good for my domestic water needs but when I use it for irrigation I suddenly have a problem. When it starts it works fine, but after about 5-10 minutes it dies down and looses pressure and volume. The sprinklers start surging and th pump sounds noisy. Then I have to shut it off to recover.
    I've resized my sprinkler nozzles down to a 6-8gpm consumption, and now i can go about 20min before the problem starts again.
    Any ideas on where to start?
    Thank you in advance.......
    Moderator valveman's Avatar
    Mar 2006
    Check the water level in the well while this is happening. I will bet the water level is being pulled down until it pumps air.
    What could cause this all of a sudden?
    Mar 2006
    It probably happened gradually. If the static water level is still the same, the perforations or screen is clogging up. Screens usually clog gradually. You just don't see it until one day the well is only making 7 GPM, while you are trying to use 8 GPM.
    Forgive me for asking a dumb question.
    But is the screen on the pump, or the casing? Is it easily cleaned or replaced?
    Is this a job for a pro?
    bump...................
    The screen is on the end of the casing.
    Previous member
    Jul 2005
    Riverview, Fl.
    It is a job for a pro.
    bob...
    Previous member sammyhydro11's Avatar
    Dec 2006
    Massachusetts
    Who says the guy has a screened well? Screened wells only need to be placed at 15 to 20 feet beyond the static water level depending on the porosity of the water bearing material. I would bet the guy has an artesian well (slang around here for rock bored well). If that's the case i would consider hydro fracturing the well. Not a job for a DIY!
    sammy
    www.tylerwellandpump.com
