Hi, I'm in desperate need of advice. We replaced our old tub with a new one thats the same size but a little deeper. I guess the building had shifted (the old tub along with it) because there is at least a 1/2 inch space along the back wall between it and the tub. The problem is that the tub is totally flush against the wall as it reaches each end. The back wall that it sits against is a concrete interior wall (we live in a duplex). Previously, the drywall was glued directly to the wall but there would be a problem with the center of the wall because the edge of the tub has to go between the wall and drywall (the drywall wouldn't stick to wall because of space). I could put up sheets of plywood to bring the wall closer to the tubs edge before installing drywall but again, each end of that same wall sits flush with the tub and would then stick out over the edge too much. Any suggestions? I'm feeling like theres nothing I can do.
Thanks, Audra
Thanks, Audra
