Results 1 to 4 of 4
Thread: 60" x 42" bathtubs with large base? (Replacing a tub-shower)
    DIY Junior Member areacode514's Avatar
    Aug 2008
    Montreal, Canada
    Default 60" x 42" bathtubs with large base? (Replacing a tub-shower)
    Greetings,
    [Background]
    We are planning to remodel our bathroom, and would like to replace our ancient 60"x32" tub-shower.
    Since there is no room for separate tub and shower, we still need to have a tub-shower arrangement in the new design. We have enough space, however, to go for a wider tub of 42".
    [My question]
    I would appreciate any suggestions for 60"x42" tubs that ideally have:
    1) curved shape that is more rectangular than oval (after all, we need to be comfortable taking a shower in it).
    2) large base dimensions so that it can comfortably fit 1 adult + 2 small children for bathing?
    I've looked around at a few 60"x42" tub models from various manufacturers, and have found that in general the base dimensions are small (example: 38" long by 28" wide, 40" long x 24" wide, etc.).
    The best candidates that I've found so far are these two:
    - Maax Casa 60"x42" with base of about 48"x28"
    - Maax Duo 60"x42" with base of about 42"x31"
    (I've quickly looked at tubs from Kohler, Americh, Jason, American Standard, Whirlpool, Toto, etc. Either the tubs are too oval and therefore not practical for showering, or their base dimensions are too small.)
    Can anyone suggest a tub that's not too oval, which would have a base of about 48" by 30"?
    areacode514
    Last edited by areacode514; 08-15-2008 at 12:13 PM. Reason: To make it easier to read.
    Customer Service Manager Plumbing Wholesale Peanut9199's Avatar
    Apr 2007
    Ontario, Canada
    Bonjour comme ce va!
    You can try Neptune they have a large selection for you i would say the "Isa" would be the best.
    http://www.bainsneptune.com/english/bains/isa.html
    Default tubs
    Je vais tres bien, merci. You are not looking in the right places.
    Jetta tubs, for example, has many 60x42 tubs that are rectangular. Some have rounded or oval basins, but that is usually for sanitary reasons. The tubs come both jetted and plain.
    Aug 2008
    Montreal, Canada
    Bonjour vous deux. Thanks for the suggestions!
    -areacode514
