Sporadic leakage visible on cross beams under the floor. Soaks beams and insulation. Able to replicate once by running all water in the house; however, unable to isolate leakage to a specific source. Suspect that the leak is coming from a hall toilet approximately 10 feet away from the leak. Water must travel under hardwood floor and then settle down into the cross beam(s) located under the hallway, just outside the half bathroom area. Toilet was recently replaced when the hardwood floors were refinished and does not rock or wobble. No visible water damage above floor, or on plywood between the floor and cross beams.
Any ideas how to definitively know it’s the toilet and not the sink? Why would something leak just occasionally? The house is vacant and up for sale so we need to know that the problem is identified and corrected properly. We believe it leaks when someone uses that bathroom, but don’t know if it is the sink, toilet or something else. My husband just wants to take up the toilet and replace the seal hoping that will solve the problem. I’m worried since the leak is so sporadic, once every week or two, that we’ll not really know for sure if the problem is solved. Any help would be appreciated.
