Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Fixing Tiny Gas Leaks
    Electrical Engineer jdf405's Avatar
    Jan 2008
    Los Angeles Area
    Default Fixing Tiny Gas Leaks
    Hello,
    I'm looking for advice on fixing a very small natural gas leak. In advance of my final inspection I did a leak test on my NG system. I lost about 0.2PSI from 10PSI in 15 minutes. I spoke to an inspector and he said there is a zero tolerance on the leak test.
    I've done some fairly extensive searching with the soapy spray bottle and found a very tiny bubbling culprit, right smack in the middle of the system (threaded black iron). I would have to cut out the piece and install a L&R - no unions allowed in the crawl space. The problem I'm anticipating is that I don't have any wiggle room to install the L&R - the pipe that would be removed is very short and is constrained between two unmovable objects.
    I guess I have two questions:
    1) Is there something that can be applied to the exterior of the joint to inhibit leaking? Or is there some way to inhibit leaks w/o unthreading?
    2) I've never used a L&R - how much room do I need to install it? What is the tolerance on getting the length right? Any other general L&R advice? All I need to do now is replace one tiny leaker with two big ones!
    Thanks in advance for your advice.
    -Jonathan
    There is nothing you can put on the outside to seal it with.
    You can either start at one end and work you way back, which is what I normally do, or you can use the fitting you are talking about, I only installed one of them, it worked.
    It took more time to find the crazy wrong threaded connection, than it would have taken to disassemble are reassemble.
    There is zero tolerance on gas. Gas kills.
    Apr 2005
    Left-right couplings always require a specific nipple that comes with the coupling.
    Make the run a little shorter near where you plan on installing this so that you have wiggle room to get the two pipes together and wind into the fitting.
    I'm moving 1.5" gas line in the next couple weeks, all of which will be 12' off the ground.
    It's going to suck and I have to use a left/right coupling to make the changes.
    Jul 2008
    S. Maine
    You put her together, now take it apart. Lot of work but it's in the crap happens department.
    Default gas leak
    What are the limits on your liability insurance? If you 'patch' the leaks the patch could fail someday. Gas line integrity is not something you worry about until the test is over, and then forget about it. If that were the case, just rig the gauge.
    About 4 1/2" including the L/R 3" nipple. But there is more to installing a L&R nipple than just screwing it in. You have to insure that both sides tighten equally so neither side leaks.
    Jan 2008
    Los Angeles Area
    Thanks for the info everyone. I've since found a couple of other extremely tiny leaks in the part of the system that is original to the house. I'm going to have to un-do the entire system - new & old - to fix those.
    I've been using Rector Seal on my threads - seems to work pretty well. Any other tips on getting a leak proof system on the "first" try? Torque on the fittings (1/2 & 3/4)?
    Regards,
    Jonathan
    Feb 2005
    Omaha, NE
    Quote Originally Posted by jdf405 View Post
    In what way is it working well?
    Jan 2008
    Los Angeles Area
    Its working well on the new pipes I've put in, as opposed to the old pipes that are leaking that were held together with 1955 bubble gum...
    Rectorseal is good.
    They have soft and the Teflon.
    Default leaks
    Use the correct sized wrench and the proper sized person to use it.
    I think of this when I change out shutoffs under a kitchen sink done with old gavlavized.
    Sometimes it's all I can do to remove the old pipes.
    And then I feel it for days.
    Jan 2008
    Los Angeles Area
    Rectorseal is good.
    Terry - that brings to mind - when would it be better to use the soft versus Teflon Rector Seal? I called the company and couldn't get a straight answer...
    Jul 2008
    S. Maine
    There is a danger that when using teflon based products, you may have a tendency to over tighten the joint. This happens because teflon lubricates very well. It is in fact possible to tighten the joint so much that the fitting breaks. Of course most of us get a feel for it after a while but I have seen a bunch of leaking teflon tape joints leak because they were tightened so much the teflon no longer sealed the joint. I like plain old rector-seal for mst everything and a product called gas-tite for gas piping.
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Fixing Gas Leaks Before They Go Boom ! ! !
    I Always Use Teflon Tape Then Coat It With Rector Seal Teflon Paste Being Aware Not To Over Tighten
    Using A 14" Pipe Wrench Instead Of 18" Or 24" On 1/2" And 3/4" Pipe
    Only Use 18" Wrench On 1" Or Above Pipe
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Dec 2007
    I only use 12" wrenches on 1/2" & 3/4" pipe. I wouldn't trust my gorrilla arms with larger wrenches on little pipes.
