Results 1 to 10 of 10
Thread: PVC schedule
    Default PVC schedule
    Hi,
    Sorry if this question is stupid.. but I am kind of new to this, but learning.
    As I understand all PVC has a maximum service temperature of 140 F
    Two questions:
    1. Does this apply to all PVC regardless the wall thickness? It wouldn't make sense, right?
    A 0.413 wall should resist more temperature than a 0.173 wall.... right?
    2. Are the the SDR series PVC and the Schedule 40 PVC made of the same material? Or one of them is more resistant to temperature than the other?
    link: http://www.harvel.com/pipepvc-sch40-80-dim.asp
    Thanks a lot,
    In the Trades Master Plumber 101's Avatar
    Aug 2008
    Wisconsin
    I thoght you could go to 160 degrees before needing to switch to cast or another type of metal. Sorry I can't give you concrete answer.
    Sch 40 PVC is rated for pressure at 73*f. No PVC is rated for hot water use.
    The only plastics that are rated for hot water applications are CPVC and PEX. And then I think the max temp is 100*f; that what is used for the pressure rating anyway.
    Plumber jimbo's Avatar
    There is some absolute temp number which is "not to ever go there" for PVC. I don't know that number. But any schedule of PVC pipe has a temperature vs. pressure spec. For schedule 40, max temp allowed for 150 PSI is 73, which is why it falls outside the range of household use.
    Jimbo, IIRC, the sch 40 I used had a 425# rating at 73*f.
    Default Pvc
    The thicker material will take longer to heat up, but once it does it will have the same problems as the thinner pipe. SDR is just a very, very thin pipe and because it is a drain material, the inside diameter MUST conform to the i.d. of sch. 40 pipes which might interconnect with it. Because of the thinner wall that means the o.d. is smaller than sch. 40 pipe and requires an adapter bushing to match the other pipe's o.d.
    Jul 2005
    Marin Co. Ca.
    Interisting pvc is used for W.H. POWER VENT exhaust
    Yes, I was a little confused on the numbers. This derating schedule shows full operating pressure at 73, and derated to 0.2 of full pressure at 140. It mentions that above 140, the plastic may not retain its shape!
    http://www.engineeringtoolbox.com/th...gth-d_794.html
    Anyway we got there, I couldn't remember the 425 until your numbers jogged my memory. It can't be used for warm or hot water.
    Default flue
    IT is mixing with cooler air so the temperature remains in the safe range.
