Thread: Help me identify and upgrade old Price Pfister 3 handle tub/shower
    DIY Junior Member prpsrv's Avatar
    May 2008
    Los Gatos, CA
    Default Help me identify and upgrade old Price Pfister 3 handle tub/shower
    Picture attached
    Can anybody help me? I am trying to change out old chrome Price Pfister handles on a 3 handle system (hot/cold/diverter) and upgrade them to a brushed nickle finish. They are old compression style valve stems which are fine. I have found kits for Verve and Windsor but can't find anything to identify what I've got. Any help is appreciated.
    Neil J. Creger
    Property Services
    CSCL #761926
    Los Gatos, CA
    In the Trades Master Plumber 101's Avatar
    Aug 2008
    Wisconsin
    It looks closer to the Windsor style. They may have been changed at one time with a similar handle.
    Default Pp
    It is the Crown Jewel version, but that means nothing as far as you are concerned because the piece inside the wall is universal to all their trim lines. If I were doing it, I would buy a complete new PP valve and then convert the body in the wall to the new ceramic seat stems. The only problem with doing it on your valve is that some Crown Jewel bodies require the the seats, (which are normally discarded), sometimes have to remain in the valve, but you cannot tell if yours do until you try the conversion without the seats. If you want to play it safe, then buy the new trim you like, the modern ones will replace your chrome trim without replacing the stems.
    Plumber jimbo's Avatar
    The answer to this type of question is usually NO. But you got lucky.
    Apparenty they used a lot of PP in Arizona, because hj is all over this one. The PP 3 handle body probably has more trim options available for upgrade than any other faucet ever made. Take all your parts down to a plumbing supply and they can fix you up.
  1. Price Pfister 3-handle shower leak
    By Mr. Pickles in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2014, 04:07 PM
  2. What shower handle would fit? Price Pfister Flowmatic 900-022
    By LynxMM in forum Shower & bathtub Forum & Blog
    Last Post: 09-29-2012, 08:40 PM
  3. How do I remove shower handle cap from this Price Pfister?
    By green30joh in forum Shower & bathtub Forum & Blog
    Last Post: 03-13-2012, 12:27 AM
  4. Price Pfister shower stall handle
    By JHOT in forum Shower & bathtub Forum & Blog
    Last Post: 09-24-2010, 05:43 AM
  5. single handle price pfister shower faucet
    By don640 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2008, 07:37 AM
