Forgive me in advance for mangling the plumbing terminology.
I am trying to replace the guts in one of my Mom's toilets. Her home was built in 1980. The water supply line turn-on/shut-off valve knob will NOT turn. It is currently turned all the way ON (all the way open) and when I started, I could see the valve threads covered in white corrosion. I brushed it off with an old toothbrush and then wrapped the pipe in a rag sopping wet with vinegar. I slipped some newspaper on the floor and left the vinegar rag there for a week to do its job. Well, I still can't hand-turn the knob. It is tight as can be and won't budge. I can't repair the toilet because I can't turn off the water. (I'm also concerned what we would do if we had a leak since I can't turn off the water supply!) What is the best way to loosen the knob? Can I use a wrench or do I risk causing a real mess? I CAN shut off the water to the house before trying - I know where that is and how to do it. Is there some kind of penetrating grease or lubricant that you guys use? A good tool? I appreciate any help or advice.
You know, I read one time that you should close and re-open every valve in the house once a year, just to keep the knobs "moveable". (Including all the ones for every toilet and both hot/cold water under every sink.) Now I believe it! I tried several others in Mom's house and most all of them are frozen tight!
Please help.
Carol
Please help.
Carol
