Results 1 to 2 of 2
Thread: Need some shower doors
    DIY Junior Member titan77's Avatar
    Dec 2007
    MA
    Default Need some shower doors
    Anybody in So. Cal have recs for a good brand and installer? I have looked at Century Shower Doors and another Mfg from Lowes. I need to put bi-pass doors in with a header and bottom rail.
    Also, should only the outside seams be caulked so water will run back into the shower area? I think if you caulk both sides you can get water trapped behind the door rails.
    The curb top should be sloped back towards the shower. Most door installations (if they use a bottom track) only tell you to caulk the outer edge. I put a Century door in my mother's shower and was impressed with the quality - I felt it was much nicer than the Kohler door I put on my tub. No extensive experience so can't help any more.
    Installation often isn't all that tough. You will likely need a diamond core drill bit, but those can be had from Lowes or other suppliers.
    If the opening is not plumb, then it becomes much more difficult and a custom door and install may be required.
