Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Double fixture tee or double sanitary tee?
    DIY Member nc8861's Avatar
    Jun 2008
    North Carolina
    Default Double fixture tee or double sanitary tee?
    For DWV on a single vanity to double vanity conversion.
    Double sanitary:
    http://images.grainger.com/images/pr...MALL-1WHU8.JPG
    Double fixture:
    http://images.grainger.com/images/products/1CNT8.JPG
    Can anyone recommend an online site for ABS fittings such as this (also on a 4x3 closet bend)? My local shops don't have them.
    If you are doing back to back toilets, it needs to be at least the double fixture fitting.
    And even with that, the waste from one toilet will cross over into the other arm, forcing the water up in the bowl, and then leaving it with less water.
    I becoming a big, I'm not a fan of any kind of cross for todays toilets.
    Jun 2008
    North Carolina
    Thanks Terry - see OP though - these are two sinks on a double vanity.
    Another question - do these fittings have the slight drain angle built into the fitting?
    Plumber patrick88's Avatar
    Sep 2007
    Webster Ma.
    The fitting you have shown are for vertical use.
    I'm just starting to work with an old friend of mine to bring solar electric and hot water systems, wind turbines, Flex Fuel Boilers, batteries, hydroponic gardening, books, pellet grills and more. Also the parts for DIY installation.
    Default fitting
    The double fixture fitting is the only one approved for back to back installations although it is possible a cross could slip by an inattentive inspector. The hubs have enough "slop" in them that they do not need built in pitch. You can install the pipe with the proper pitch, reverse pitch, or 'excessive' pitch just by holding the pipe at the desired angle as it cures.
    Geologist sjsmithjr's Avatar
    Dec 2005
    Knoxville, Tennessee
    Default Here's a pic
    The pic below of double lav install (I believe it's from one of Terry's jobs) shows the correct configuration using a double fixture fitting. For the ABS fittings, Google "plumbing supply" and go with the famous one.
    -Sam Smith
    Licensed Professional Geologist - AL, TN, KY
    Default picture
    The only addition to the picture, unless it is dropping directly into a main line would be a cleanout tee beneath the fixture fitting. Although a snake will drop down the stack, removing a trap to clean the line is not a proper cleanout method in this area.
    Jun 2008
    North Carolina
    Thanks all - I do already have an existing cleanout beneath the existing (single tee) fixture. I'm planning to cut above and below the existing single tee, & add my double tee.
    When adding a section of dwv pipe back in this vertical way, what's the best way to get couplings squeezed in there? In other words - if I come back with pipe to fit the exact length that I cut out, there won't be room to get couplings in where I need. I was thinking that I glue the bottom joint (between the tee and cleanout), and then on the top joint (above the tee), I use a rubber coupling? What do you all think?
    Jun 2008
    North Carolina
    Sam - Just for the sake of explanation - why don't you use the type you pictured in the lower picture?
    Jun 2008
    North Carolina
    And just to review - it's only when I'm doing a back-to-back installation (i.e. two different rooms) where I need a double fixture tee, right? Same room, two sinks = double sanitary. Correct?
    Where I am at, you would need a double fixture fitting, regardless.
    Dec 2005
    Quote Originally Posted by nc8861 View Post
    My 50 cent explanation: the steel band in upper pic reinforces the coupling making for a connection that won't offset or separate. The coupling in the lower pic relies on the soil backfill to reinforce the coupling.
    Also, look closely at the coupling in the first pic - notice the stop for the pipe in the center and the ridges at either end to seal the joined pipes. The coupling in the second pic does not have these features.
    -Sam Smith
    Default fitting
    The same fitting regardless of where the sinks are located.
    Jul 2008
    S. Maine
    The IPC will let you use the double san tee in the configuration that you want to use it for, HOWEVER if you have to snake the drain you'r gonna have troubles because the snake is going to pass straight through and not go down. We can not use double san tee fittings for back to back blow out type fixtures. I would follow Terry's advice and go with a double fixture Tee.
    Default code
    The IPC is a cost driven code, and since a double fixture fitting costs more than a cross, the cross will be allowed even if it does cause operational problems later.
