Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
Thread: How to use root killer?
  1. #16
    Thumbs up Jerry
    Quote Originally Posted by MACPLUMB 777 View Post
    Yes He Is Using A 3" Cutter " And " A 3/4" Cable
    WHICH MAKES ALL THE DIFFERENCE IN THE WORLD WHEN IT COMES TO CUTTING ROOTS
    Jerry,
    I must say, I'm very impressed with your professionalism and knowledge!
    You nailed my problem and saved me a ton of money!!
    My mother has been suffering from Parkinson's and Dimensia in the last few years. Recently an adult care center, that my sister left her in while on vacation, nearly overdosed her to death!! We wanted badly to go to NJ to see her, but had no idea how we would afford the trip.
    Now...not only can we go see her, but it will be at Thanksgiving!!
    Thank You very much!
    Sincerely,
    Ray
  2. #17
    Nov 2008
    Chicago, IL
    I have been cleaning sewers in the the Chicago area for 24 years now. Most homes here have 4" cast Iron under the house and when it leaves the house approx 5' out it goes into 6" clay pipe. These homes only have a 4" clean out on the stack so trying to get a 6" expanding cutter through the line is real pain in the arse. So I have learned how to clean the line properly with a 4" cutter. We start off with a 2" then to a 3' and finally two passes with the 4" cutter cleans the line out extremely well. I had a village inspector put a camera in the line to try and prove to me that I "needed" to get the expanding cutter through. To his surprise the line was root free. Our company guarantees its power roddings of the main sewer for two years.
    Now to address the roots growing in the top of the pipe here is picture showing such. And Rootx will get to the roots growing in the top since it does foam through the whole pipe. Now I have seen clay sewers that are over 100 feet long trees growing around the area like a forest preserve and not a single root growing in to the drain at all. The old timers used to know how to properly install the clay pipes. The issue with the pipes installed from the late 1960's to present day is all this labor saving crap like slip-seal joints.
    Some people say PVC sewer lines will never get tree roots, they lie. A fact roots grow in through the joints in the sewer pipes. Yes clay comes in 2, 4 and 6 foot long pieces. Most common is the 2 footers. So every two feet roots can grow in the pipe. Plastic SDR 26 sewer pipe comes in 13 foot lengths which roots will still grow into but much less joints for this to happen. Here is a picture of roots pulled out of a plastic sewer line.
    If RootX does not help we recommend to all our customer's that do not want to dig and replace the sewer to have the sewer properly rodded every two years as preventive maintenance. Just like you have to cut your lawn every two weeks. Oh another thing that can help is water your trees, get root feeders and and that and keep your trees watered. This will help the grow in the soil instead of seeking out water in the sewer pipes.
  3. #18
    Dec 2007
    I usually start right out with a 3-5 pear offset blade with a whip in front. I always like the idea of trying a one pass cleaning.
    If it loads up with wrapped roots and stops advancing, I pull it back to clean it off and send it in again. If it won't advance and is being held back by the whip, I take off the whip. If it still won't advance I then start dropping size to get through probably down to a 3" apple.
    To punch a hole then go back up to the 3-5 pear offset to complete the cleaning.
    Many times I get the 3-5 pear offset to go through on the first pass.
    Big Truck, I'm concerned about the dia. of those roots. They do look like they are of a size where the pipe may be damaged.
    Definitely start with a once a year treatment of Root-X. I would advise you to hit it in the spring when the tree goes active again.
  4. #19
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Exclamation How to use root killer
    Redwood;
    i agree with your blade choices, with the whip
    this was growing "outside" the pipe but grew up around the closet flange
    and down inside the closet bend without showing outside the base of the toilet it grows though the wax seal,
    I told Bigtruck to pack rock salt around the outside the flange, and set
    new wax down to stop roots from growing back anytime soon,
    By the way this is all sch. 40 sewer pipe
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
  5. #20
    Dec 2007
    Ah yes now that I go back and read more... I see it.
  6. #21
    DIY Junior Member rckowal's Avatar
    Dec 2006
    Michigan
    Default How Do I Use RootX?
    I've read a lot about RootX, but I never seen much said about exactly how to introduce it into the pipe where the roots are.
    The reason I ask is that anything that foams has to be applied in the right place or it may not move through the sewer line to the roots. For instance, if I were to put it into a floor drain with a trap - when it foams I would think that it would just foam back up & out of the drain. In a case like this, it would never get to the roots.
    The other case is where there is an 8 - 10 foot run of floor drain without a trap. If I pour RootX in the drain opening, how does it know it's supposed to flow through the pipe to where the roots are? Again, I would think that a lot of it would just foam back up & out of the drain.
    Maybe I'm wrong or missing some thing. A chat with RootX Tech Support was a waste of time. They just tell you to pour it in the pipe. That's why I'm here asking those of you who use the stuff professionally how it should be done. Replies will be much appreciated.
    Richard
  7. #22
    Apr 2005
    Whatever you do, absolutely DO NOT mix water and RootX outside the piping system.
    You're whole basement will be full of foaming root killer.
    You want to hit a floor drain or pull a toilet to hit where the root intrusions were likely found.
    If roots were found inside the structure, in the piping, you need to access the furthest distance inside the house and apply it from there.
    Dumping RootX in a toilet will also have foaming root killer everywhere in the home.
    A floor drain is the best bet or cleanout, just have a bucket of water behind it, absolutely no urinating in toilets, no water at all in the drains for 6 hours.
    Just leave the house completely to keep from pushing that foam down the line where it serves no purpose.
    The most effective way to use this product:
    Very aggressive drain cleaning/root cutting and THEN apply RootX.
    This will minimize the work the foaming agent has to do and this kills the roots, but they die off months later and fall off, float away in the drain.
    I had a dream one night and I thought I was a root cutting blade, and saw all this in the drain until my wife took a dump and her morning pile came and flooded me out to sewer. That one is going to require counseling for sure.
  8. #23
    Dec 2006
    Michigan
    Hi Rugged, Thanks for your very helpful reply. I have a few questions
    "You want to hit a floor drain or pull a toilet to hit where the root intrusions were likely found. If roots were found inside the structure, in the piping, you need to access the furthest distance inside the house and apply it from there."
    The known root activity was found in the end of the storm sewer, at the house cleanout, where some weep tiles drain into the main sewer line. This is right near an exterior wall where the main goes off to the street sewer. This is about 8 feet from either of two floor drains. Should I put the RootX in one of those drains?
    "Dumping RootX in a toilet will also have foaming root killer everywhere in the home."
    Please clarify. Are you warning that the foam will back up (unwanted) into the house? Or, introduce it into a toilet to get it into all of the lines?
    I assume the bucket of water is to be poured into the same drain/clean out where the RootX was introduced - to activate it?
    The most effective way to use this product: Very aggressive drain cleaning/root cutting and THEN apply RootX.
    The roots were first cleaned out two years ago. They could actually be seen from the clean out. It was like a small birds nest of fine hair like roots. Sand from the weep tiles had built up in the birds nest - eventually blocking the storm sewer drain. Drain cleaner guy ran the end of his snake into the nest then reached in & removed it by hand.
    As a preventive action, that line was snaked again about 9 months ago. I have also been putting a bottle of (blue-copper sulphate) root killer in the floor drain near there. I check that spot every fall to see if any new roots have formed.
    A great concern however is whether there is root growth in the weep tiles around the exterior of the basement walls. Is there some way RootX could be used to kill those roots as well?
    Richard
  9. #24
    DIY Junior Member Last Person's Avatar
    Jan 2014
    Mississippi
    Quote Originally Posted by Bigtruck View Post
    Nobody ever said they were on the outside! I said they were on the top. I had no idea someone would actually think I was talking about the "outside" of the pipe. LOL.
    To be fair to HJ, I thought the same thing and thought you were on crack or something for saying it.
    I just had Rotorooter come out and clear my lines. I just got a house built in 1946 and it still has the original clay (terracota?) pipes and there were two or three spots where roots had grown through. I know I am going to have to replace the entire line at some point, but I am hoping to stave that off for a bit, so I was looking at the Root-X stuff as a stop-gap until I have the money to get the line cleared. I was thinking about getting bottle and running it down ever 3 or 4 months. I was looking at the Zep Root Killer. It is pretty inexpensive and is a foaming kind.
  10. #25
    Aug 2007
    Get the root x and be good for a whole year,
    best on market
    30 year master plumber and drainman
    MACPLUMB 777
    E-MAIL
  11. #26
    DIY Senior Member Reach4's Avatar
    Sep 2013
    Quote Originally Posted by Last Person View Post
    In defense of Bigtruck, I see that https://www.rootx.com/plumbers/how_it_works contains "the top of the pipe where 90 percent of pipeline roots grow."
  12. #27
    30years plumbing 10years plumbing inspector Bill Shack's Avatar
    Mar 2014
    montreal quebec Canada
    We have the same problem with roots in quebec with clay pipe. I have found that if the joints do not leak then there are no roots However if the joints leak then the roots will sense this nutrient rich water and then grow in to the pipe. a lot of plumbers are suggesting to their customers to have the drain pipe lined with a epoxy membrane. much cheaper than digging up the pipe and redoing it.
