TVL
A few weeks back I posted a thread with some well concerns and got some very good responses. Armed with the information, I pulled the submersible pump and discovered the galvanized connector located just above the pump was badly corroded and was leaking. This is the connector which attaches the pump to the 1 inch poly pipe. I thought to myself, great ................. this is my problem and it should be an easy fix. Well, it certainly was "A" problem, but not the complete problem.
I replaced the entire 132 feet of 1 inch drop pipe with new pipe and new fittings and dropped the pump once again. The pump now runs for approximately 3 hours with a completely steady 36 PSI. After approx. 3 hours the pressure will begin to drop a small amount and begin fluctuating. After about 5 hours of continuous operation, the presuure gauge will indicate about 31 PSI and every 5 or 10 seconds the pressure will drop to approx. 26 PSI and then quickly return to 31 PSI.
1- Can a submersible pump that is possibly on its last leg cause this type problem? (the pump is 13 years old)
2- If so, how? I really do not want to replace it unless there is good evidence the pump is failing.
This pump and well is used for irrigation purposes only .............. so, I do not have to do anything right away. But, all responses are appreciated!
