cybervex
What is the R-Value of insulation needed between plumbing and outside wall if plumbing is running in an exterior wall?
This is in Michigan.
Thanks in advance.
Thanks in advance.
Keep in mind that insulation does not stop heat movement, it only slows it down nor does it make heat. If it is a really cold day, you leave the gargage door open, it's windy, etc., or go away and lower the thermostat, the pipes in an exterior wall may freeze - then, when they thaw, big problems.
At this point it is not a code issue, it is an inspector issue, so you have to run it by him. If you do it and he doesn't like it you will still have to move the PEX or change the wall.
I have never managed to get my HT-200 to thaw a PEX tube yet...
Seems I can't get a good connection for some reason...
