I will try to keep this short. About 3 months ago I noticed that sometimes my well would cut on when the pressure dropped to the lower set point (45#). But pressure would just drop down to like 20# or lower and stay there with the pump running and it was unable to recover until you cycled power to the pump, turn off the breaker for about 10 seconds then turn it back on and pressure would build up fine. Well the pump finally died last night. The pump had 220v going to it but it was not drawing any current. So I pulled the pump today and installed a new submersible pump, however they installed a 1 ½ hp pump and the other one was a 1 hp pump. So the new pump was doing alright and I went to check my sprinkler system to see if I have to go up on the nozzle size due to the larger pump. And when I started the sprinkler the pressure dropped and the pump kicked on at 45# like it should then it dropped down to 25# or so and after 30 sec pressure built back up to normal then since I had the added gpm from the bigger pump, pressure built up to 60# and the pump cut off then of course the pressure dropped again and the pump started but this time the pressure did not want to build back up until I turned off the sprinkler valve. Side note the sprinkler is set up for 12 gpm and the old pump put out right at 12 gpm so it would stay running the whole time but the new pump is rated at 15-17 gpm. My few questions are:
1 why would the pressure not build back up. And would that have fried my last pump.
2 should I have something to limit the initial flow until all sprinkler lines are filled with water to keep the pressure from dropping that low (ie is it not good for the pump)
3 what size pressure tank do you recommend, the well is for the house and the sprinkler and right now I have a 20 gal bladder tank and it just seams like the pump cycles a lot while a faucet is running. (maybe 15 times a minute).
any help is appreciated
Jason
Jason
