I have an old pier and beam rent house that was replumbed when the bath was remodelled. It has new PVC on the cold side and CPVC on the hot. A Delta R10000 single handle valve body is in the tub which I believe has a brass body and 1/2 inch male threads. Coming off on the cold side is a 1/2 inch threaded PVC fitting which is attached to the supply line, glued 1/2 inch pvc. So far I've had 2 of these fittings leak.
The first time the 1/2 inch pvc fitting was cracked probably from overtightening on the brass threads of the valve body. This time the new pvc fitting looks like it has about 5 small pin holes in the side of it spraying out water.
It's a royal pain to get to since the wall is freshly tiled and I'm coming in from an access hole behind the faucet body. Would I be better off using a 1/2 inch cast iron union on the valve body side and then a male threaded PVC fitting to attach the glued pvc side connection? Thanks.
