Results 1 to 13 of 13
Thread: Where to get water heater anodes?
    Default Where to get water heater anodes?
    Looking for some places that have flexible magnesium anodes. Google is not really helpful in this case. The Big Box stores don't seem to carry. Live in Spokane, WA. Internet will also work.
    Is an A. O. Smith FGR40 gas model. As it is 14 years old, I suspect that the original anode is gone.
    Open to either replacing the original or using a combo rod.
    Would prefer not having to drill out the existing holes for a larger diameter rod, as discussed at waterheaterrescue, due to clearance issues.
    I saw one at the This Old House web site that would suit. It is segmented like a martial arts weapon.
    Thanks in advance!
    DIY Senior Member jch's Avatar
    Jan 2006
    Victoria, British Columbia, Canada
    Here they have them at Big Orange (HD). I bought one there recently.
    .../j
    Nov 2006
    Quote Originally Posted by mortimer View Post
    Here is flexible aluminum:
    http://www.**************.com/anoderods.html
    Oops! That is a plumbing supply store that must be on the edit list here.
    Feb 2005
    Talking 14 year old heater
    getting that old mag rod out of your heater might be
    close to impossible....
    sometimes you allmost have to kill the patient to
    get out that rod.....they wont budge..
    we have given up on a quite few
    that was with one fellow
    holding the heater frim in place and the other fellow
    trying to pry the rod out with a heavy duty socket wrench
    and a cheater bar.......
    so before you go out and buy one......
    might I suggest you see if the
    old one is willing come out of that 14 year old heater
    without turning into a "man hood " contest???
    being that old, you might want to let sleeping dogs lie....
    Dec 2007
    Try this google search...
    http://www.google.com/search?hl=en&a...i=&safe=images
    I have used the "Famous" one.
    When replacing an anode if you attempt it using a regular wrench the twisting force on the water heater is very high and may cause damage. I use an electric impact wrench to change anode rods and it works very well. At the factory they are originally installed with an impact wrench.
    As Mark posted your water heater is very old and depending on its condition sometimes it is best to let the sleeping dog lie.
    Default anode
    I have not been to that site, but I cannot imagine ANYONE trying to drill a water heater so you could install a larger diameter anode rod.
    Dec 2007
    I would agree HJ, sounds like bad advice to me!
    Thanks for the replies!
    Central Florida
    There's also an obscure and expensive tool called a "torque amplifier" that fits on a large socket wrench and, as the name implies, amplifies the torque being applied. You might be able to borrow one from someone who owns and/or works on buses or trucks. I'm told they work well on anode rods. I've used impact wrenches, but always had visions of the glass lining breaking up when I use them.
    Dec 2007
    The torque multiplier still exerts a twisting force. There is a reaction bar that extends from it that could rest on the inlet or outlet pipe... They are used more on heavy equipment than anything else. Still might break something or, round off the nut. There is a reason why they use impact wrenches to put in anodes at the factory... Cause they figured out that it works!
    Feb 2005
    Talking too much time on their hands .....with too little to do
    they just have too much time on their hands
    and they got to be absolutely nuts to try to drill out a anode nut to attempt to change it out.
    I supppose you could get lucky with an impact wrench,
    I have moved a water heater out of place before useing
    the cheater bar and heavy duty socket....
    I never promise the customer that I will get it out.
    only that I will try .......
    everybody must be slow today...............
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    Default Water Heater Anode Rod
    Go To
    Hotwater.com This The A.o.smith Website Go To Parts
    They Can Send You A Flexible Anode Rod That Replaces The Hot Water Nipple At Top Of Water Heater,
    Which Is Better Then Trying To Get Old Rod Out
    Remember We Are Professionals Who Do This And We Would Not Attempt That On A Old Water Heater :d
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Feb 2005
    Talking thats a better idea Mc plumb
    Quote Originally Posted by MACPLUMB 777 View Post
    Go To
    I had not thought of that, I suppose if you had to change out an anode rod , their is no rule that you got to remove the old one... just install a new one on the hot outlet port of the heater... who cares wether you remove th old one or not
    you can get a replacement anode rod with the attached nipple about anywyere..... Bradford Whites anode rod is attached to the hot nipple
    it would work fine
    but it still is a lot of trouble..
