Guys,
I just found this forum and need some help. I currently have a 4 year old Grundfos CU301 system that I use for grass irrigation and house water supply. Well tonight the box went dead. As I happen to be a troubleshooter (mostly because I hate to pay someone money for something I can do myself) I took the cover on the CU301. No lights on the outside were showing and when I opened it up, it had a steady green LED for 24V, a flashing green LED for 10V and 5V and a flashing red LED for NO CONTACT WITH PUMP. I downloaded a copy of the user manual and tore into the troubleshooting section. I did what the section said and hooked the power supply directly up to the pump supply to see if the motor works. It did (small victory as we now have water back in the house for needed emergency plumbing issues) so I went on through the troubleshooting and it says that the CU301 box is defective. Just a curiousity, but what would have gone bad?
Now my real questions are after reading your information about constant and variable speed pumps and cycle stop valves:
What should I do about this system?
Should I replace the CU301 box with a new one (approximately $350) and hope that it lasts for x months more?
Go to a whole new system since I am nearing the service life for this POS and what system do I get?
Or what?
Any information will be greatly appreciated.
Mike
Or what?
Mike
