Results 1 to 15 of 17
Thread: TOTO Aquia III, CST464MF dual flush toilet product review, three and two
Hybrid View
    Default TOTO Aquia III, CST464MF dual flush toilet product review, three and two
    The new Toto Aquia 3, CST464M dual flush toilet product review.
    Aquia three, Aquia III
    Pictured with the Toto SS204 softclose seat in Cotton White.
    The smaller side of the button is for the small flush, the larger side of the button is for the larger flush.
    With the seat lid open.
    Looking at the back of the bowl. The drain from the bowl fits into an adpapter that comes with the bowl.
    Installation instructions for Aquia
    Complete Instructions for the Aquia written by Jamie
    The front of the tank where it meets the bowl.
    The tank from an angle.
    Side of the bowl, ready to be installed.
    It's 16-1/8" to the top of the bowl.
    About an inch higher than the Aquia I or Aquia II
    http://www.easycarts.net/ecarts/terr....html#CST464MF
    DIY Senior Member SamC's Avatar
    Apr 2007
    Georgia
    What are the differences, other than height, among the Aquia I, II, and III?
    DIY Member GregO's Avatar
    Oct 2004
    Virginia
    Default thanks!
    Thanks Terry!
    First glance I was thinking I don't like the shape, but then I realized cleaning the outside of that bowl looks like it'd be a lot easier than pullilng crud out of the "twisties" of most standard bowls.
    Greg
    Toto has a number of skirted toilets...I have several. They are much easier to keep clean.
    Customer Service Manager Plumbing Wholesale Peanut9199's Avatar
    Apr 2007
    Ontario, Canada
    Quote Originally Posted by SamC View Post
    Look at this web site it gives you the info.
    http://docs.hdpi.com/PE-Links/Toto/T...risonChart.pdf
    New model looks good.
    Any update on Aquia II or Aquia III performance? How well do they flush and keep the bowl clean. I am more interested in Aquia II because I do not need ADA height.
    And how involved is installing Aquia II or III?
    Could not find instructions on the Toto site. Should be easier than original Aquia.
    Thanks.
    The Aquia I has a MaP rating of 800 grams using the adapter on the left.
    The Aquia II and III use the adapter on the right, with a different bowl design with internal trapway.
    Back of the Aquia I bowl
    Top of the Aquia I bowl
    Back of the Aquia III bowl
    Quote Originally Posted by kolo View Post
    Thanks.
    My wife and I are also looking at the Aquia model with the dual flush buttons. I was originally planning on the Ultramax, as it has a two flush system as well. However, as you need to do a quick flush to get the small one, and you need a long flush for the regular 1.6 gpf, my wife was worried about having to explain this to guests. We are hoping the Aquia should be more intuitive
    I too am curious how the Aquia II/III perform in the real world. Any word yet Terry?
    Also, can you please confirm if there are any technological differences between the Aquia II and the III or not?
    From the PDF link above, it looks like the III has a slightly different bowl shape, a larger, more encompassing skirt, and a sleeker tank. The III is a bit taller, but the PDF seems to imply that the II will be getting a height upgrade this fall as well.
    The Ultramax uses either 1.6 or somthing like 2.5 gallons if you hold the handle down.
    The Aquia uses 0.9 or 1.6 gallons.
    The TOTO pdf is confusing or clear depending on whether you understand their logic. Most people are getting it wrong.
    Bowl height measured with on old fashioned tape meaure.
    Ultramax 14-1/2"
    Ultramax ADA 16-1/2"
    Aquia I, 15-1/8"
    Aquia II, 15-1/8
    Aquia III, 16-1/8"
    And then you add a seat, which gives you another inch or so.
    The Toto pdf is measured to the top of the seat.
    Either toilet flushes solids very well with 1.6 gallons.
    The Aquia II and the III work pretty much the same, using the same tank parts and the same floor attachent.
    Thanks for the quick reply! Wow, I had it totally backwards on the Ultramax. I assumed if it had dual flush capabilities that it would of course use less... oops.
    Assuming there isn't too much of a price differential between the II and the III, I'm guessing we'll go with the III for increased aesthetics alone. Thanks again!
    Except those with the special flush valve, NONE of the low-flow toilets were designed as dual flush, and use their stated volume with just one full-throw push of the handle. It was not designed as a dual-flush. Nearly any low-flow toilet will use more water if you hold the handle down to empty the tank, but, if it is well-designed, shouldn't need it. Unfortuneately, not all toilets are up to the task. For a new owner of a Toto, it just looks like it could never empty the bowl with that short flush, but except in rare circumstances, does it very well.
    I'm really interested in this new design -- now that it has the comfort height.
    I checked my local Toto dealer -- they don't have them available as of yet and couldn't give me a time frame of when they would be available.
  1. Toto Aquia dual flush toilet product review, comments and posts.
    By stimpsonjcatt in forum Toilet Forum discussions
    Last Post: 01-27-2014, 09:32 AM
  2. Replies: 0
    Last Post: 08-04-2011, 05:50 PM
  3. TOTO Neorest 550 MS980CMG Dual Flush product review and comments
    By Terry in forum Toilet Forum discussions
    Last Post: 07-20-2011, 10:09 AM
  4. AS Flowise Dual Flush = Toto Aquia???
    By Scorponox in forum Toilet Forum discussions
    Last Post: 03-25-2008, 10:01 AM
  5. Non-Pro Advice on Dual Flush Toto Aquia
    By Mike50 in forum Toilet Forum discussions
    Last Post: 10-29-2006, 09:21 AM
