WD 40 is not a penetrating oil. PB Blaster is about the best stuff going right now. Spray the joint, let it set for awhile then repeat. It will still take a good sized wrench to remove the elbow. If you still can't get it off, you may have to open the wall and cut above and below the tee the elbow is in then use banded coupling to attach your PVC.
