Results 1 to 2 of 2
Thread: Toilet Water Level Drops
    DIY Junior Member
    May 2008
    Southeast
    Default Toilet Water Level Drops
    I have noticed that when I flush my Toto everything works as expected. Later when I come back the water in the bowl had dropped down quite a bit. Flush it again and the same thing happens. Throughout all of this the toilet works fine. Any ideas?
    Dec 2007
    If you add water slowly to the bowl with a pitcher does the water level rise?
    It may be either the normal water level in the bowl regulated by the height of the trapway, or, there may be a crack in the trapway allowing water to leak down the drain. This crack would be internal where you can't see it.
