Results 1 to 5 of 5
Thread: Bathroom remodel. Couple Questions.
    Default Bathroom remodel. Couple Questions.
    First off, I am remodeling a bathroom in a 33 year old home in Phoenix AZ. The bathroom has a 3'x5' shower stall with a standard sink and toilet. I have ripped all the drywall out and the tile. The tile is original and was adhered to the drywall. Surprisingly ( or not) there was no mold behind the drywall. Two walls of the shower are exterior walls and the third is an interior wall. I have gone round and round in my head about what backing material to use for the new tile wall to be put up in the shower. As it is, the old drywall held up for 33 years. But from my understanding, drywall is the old way of doing things. I think I have pretty much convinced myself to use Durock as the backer board. For the exterior walls, where I will be putting Durock, is a vapor barrier really necessary (6 mil poly or felt)? If I water proof the Durock do I need the vapor barrier? The exterior walls will have new faced insulation installed. When I butt the new drywall up to the Durock, how do I join the seams? Do I use standard drywall mud and tape or is there a different technique?
    Any advice will be greatly appreciated.
    Dan
    Dec 2007
    I guess you were very lucky with that "old school" shower..,
    This new Kerdi System doesn't require any luck!
    Take a look at this link...http://www.johnbridge.com/kerdi_shower.htm
    Plumber jimbo's Avatar
    The issue of a vapor barrier on an exterior insulated wall has been discussed before. I think possibly you should use unfaced insulation, covered by the poly under that cement board. You should probably discusss this with a general contractor, and also check over on the tile board....www.johnbridge.com
    You probable saving grace was that many places in Arizona are exceptionally dry and hot for a good part of the year. You would not have had that success in most other places. Best to do it to industry standards, then there's no chance about it.
    Thank you for your responses. Much appreciated.
