Results 1 to 15 of 15
Thread: Which panasonic bathroom fan?
    DIY Member fidoprincess's Avatar
    Jul 2008
    Aptos, CA
    Default Which panasonic bathroom fan?
    Bathroom 6 X 9 and being totally redone-no fan now and no one opens the window. I saw one model with a sensor, liked the idea but will the cat set it off? This is the one I was thinking about
    http://www2.panasonic.com/consumer-e...00000000005702
    Or should I just go with the cheapest one? The bathroom has a large walk-in shower 3.5 x 5.5 so do I put it above the shower, in the shower or outside above the toilet?
    I only have 2 more openings on my electric panel and want to put a heated mat in under the tile floor so I am not sure I can have both, can I do it?
    Thanks in advance for your help!
    Nov 2006
    Quote Originally Posted by fidoprincess View Post
    Probably not, and the sensitivity might even be adjustable. Personally, however, I prefer my touch-button switch with a programmable timer so the fan does not run just because somebody stepped in only to wash his or her hands for dinner.
    I have mine between the two, and I believe directly above the shower would be a problematic location. Then, I also have a dehumidistat high on the wall just outside the shower to keep the fan running even after the timer drops out if the humidity is still high:
    http://thermostats.idtenergystore.co...product=110198
    A mat for that size floor might only draw around 5 amps, so I believe you should be able to run the entire bathroom with one circuit. I have two circuits only because I have a fan with a heater that draws more than the floor.
    DIY Member rburt5's Avatar
    Jan 2006
    Canton, Ohio
    Don't go with the cheapest one. That is what I did and I regret it. It is really loud. Much louder than it sounded in the store. At least go with a mid-level fan.
    Figure the volume of the room LxWxH in feet, then look at the cu ft/hour rating of the fan. You want to be able turn over the air multiple times (say 8x - double check that value but I think it's close) in an hour. that will show you what size you need.
    Jul 2008
    Aptos, CA
    Thanks so much for your replies! leejosepho, What a good point! I would not want the fan running everytime someone went in either. I'll put it outside the shower too. I like the timer idea too. rburt5, I was warned not to get the cheapest one but honestly, these are UGLY compared to some of the $80 fancy light ones at HD. They are really attractive but I am trying to be smart about things.
    So now it is between these two:
    http://www2.panasonic.com/webapp/wcs/stores/servlet/vModelComparisonResults?storeId=15001&catalogId=13 401&catGroupId=75112&surfCategory=Ceiling%20Insert %20Fans&cacheProgram=11002&cachePartner=7000000000 000005702&items=249664|62438|
    11vh2 is $190 and 11vh1 is $$220 (Best prices I've found anyway)
    Which should I get?
    I was thinking if I get the fan with the heater now, I would skip getting the floor heat and save $350. I am in CA and it rarely goes below 55 at night. Do you think I will regret skipping the floor heat? On a budget you know and every little thing I can cross off helps.
    Thanks in advance!
    Sally
    DIY Hillbilly Southern Man's Avatar
    Jun 2008
    North Carolina
    Quote Originally Posted by leejosepho View Post
    .....directly above the shower would be a problematic location. ......
    With the chosen models, yes. The spec sheet on the first states so.
    I have two panasonic through the wall units mounted above the wall in showers that are UL listed for that location when they are on a GFCI circuit. They are very quiet and well worth the price.
    Jul 2008
    Aptos, CA
    I think I've found the answer to which model? From another website:This product(11vhl1) has been discontinued. Available in Limited Quantities. Replaced by FV-11VHL2
    I guess I will go with the 11vhl2 and save a few $$s, Sound right? Going to order this today!
    Jul 2008
    Aptos, CA
    Good luck with ordering! I used the mfg coupon code and got 25% off and it was $160! I think that is a good price and I'm happy!! Thanks so much for all of your help-now on to the plumbing-ugh!
    Nov 2006
    If you have never had it before, probably not. However, I can tell you it is really sweet for your feet, and our cat would not even think of sleeping anywhere else during winter.
    Jul 2008
    Aptos, CA
    Aonther question, please? (posted this earlier but don't see it..hope it's not a double)
    I was going to get the (4 gang) electrical box and a switch for the fan-found a nice compact rocker switch with 2 up and 2 down, very nice and compact. I was thinking each function would have it's own switch-fan, heat, light and nightlight.
    Then I realized that I still have a switch at the door for the vanity light. What is the "normal" way to wire this stuff. The 5 switch looks a bit much? Plus they didn't have the nice rocker ones, just the toggle ones. Put a single next to the quad? Move one or the other to a different location not next to the door?
    The vanity light switch (main light) is right over the vanity/sink as you walk in the door. One the other side of the vanity at the same height is a receptacle and around the corner of that is another switch for the shower light at the shower door. Where should I put the new one?
    Thanks for your help with what is probably a silly question but I just can't picture and think of how it is "supposed" to be done!
    Nov 2006
    I would probably put the switch for the heat somewhere else and by itself so it is less likely to get turned on and left running by someone not familiar with the matrix.
    Jul 2008
    Aptos, CA
    Thanks leejoespho, For some odd reason I thought all 4 of the panasonic unit's switches had to be together in the same box! Are you sure they can be split up?
    If I can split them up, I will put the heat one next to the shower light switch-that makes the most sense right? Then I would have the fan, light, nightlight and vanity light at the entry door and the heat and shower light about 4 feet away at the door to the shower. That will look nicer and be more practical too. Thanks!
    The wiring may be more complicated to split things up, but it is definately possible.
    DIY Member George R's Avatar
    Mar 2005
    Central Illinois
    You could also simply convert your old single box (inside the door), to a double box and wire it such that both lights (vanity and new light) come on with the single light switch on your new quad setup. In my opinion this would give a much neater and more professional look.
    If you do it this way, pay attention to "box fill" requirements.
    Jul 2008
    Aptos, CA
    George, that is a good idea but I want each light separate simply because my vanity light is soooo beautiful. I went last night to get all the switches and oh boy, it was tough.
    I finally picked the 4 light switch and then the 2 light one thinking I would split the heater off. I had to get a metal box instead of the plastic one because they were out. Is that okay? Does it matter which one?
    Then when I got home and opened up the fan, it was the wrong darn one-grrr. I knew that price was too good to be true even though I had the right fan #. The one they sent doesn't have the heater so I have to send it back and now mysteriously they don't have the heater one to exchange for the right one so I will have to find it locally. No more ordering off the net for me but I am hoping my sink and light will be okay when they come.
    I also needed a new light can for inside of my shower and the "brightest" I could find would only take a 75 watt bulb, is this a new thing? I had to pick the remodel/insulation contact and that was the only one. Only one new construction light was 150, the rest were all 75 or even less?
