Hello All:
New to this forum as a result of some issues with my well. I recently noticed a significant drop in water flow to my lawn. I have about 1/2 acres of front yard irrigated. I thought this was mostly due to faulty backflow that was damaged in the winter, however have since seen this to not be the case. About a week ago I called the original installer of well (house was built 3 years ago) and explained that pressure was down. I was not there when the service tech arrived and told my friend who was there in advance to make sure they check the system but do not turn the sprinkler on (big mistake on my part). I didn't want them to assume the probably was the sprinkler. Reason for this was this company initially installed my well at around 250 feet, it failed due to sand, redrilled at around 250' in another spot same problem. Went to 440 and pulled up sludge, settled on another one at 220 which still had sand but installed an aquacore filtration system. So, guy tested at the pressure tank last week, said everything was fine and left.
A week later I had my backyard irrigated (1.5 acres, 80 heads on 10 zones). I held this appointment up until the well was cleared. Sprinkler system installed, and they replaced the preventer. Problem now is I cant run any zone for more than 10 minutes, even the frontyard on 4-5 heads. Tank drops down to 10, sometimes 5 psi. So I called another well company. Guy came out today and dropped the pump another 45ft (he has done about 10 service calls in 2 square miles of my house, said water level is down 25-30 feet). Also replaced first 30 feet of pipe which he said was poor quality, and replaced a galvanized adapter at the pump with stainless. Pump is a Myers 1.5 rated at 20 gpm. He drops the pump back in, we run it at the pump(house is off at this point). Runs for about 5 minutes sucks dry. Wait another 5 minutes, sucks dry and over and over.
I have no problems in the house as he indicated the well can easily recover, however with the sprinkler system the well can't catch up. He recommends blowing out the well (50/50 chance it will work), or I need a new well (5-6k). He also thinks I should go back to the builder as he feels the well was constructed poorly from everything he saw (piping, adapter, no conduit with wire, multiple drills etc). From what I see on my warranty this is not covered as I am past two years, only water quality. Anyone have any advice, I figure I just spent 400 today on dropping the pump, so if I was a gambling man 50/50 at $500 more looks better than 6k. Any help is greatly appreciated.
-Mike
-Mike
