Results 1 to 6 of 6
Thread: Toilet Flange Too High
    Default Toilet Flange Too High
    Hi all ...
    I have to install a toilet in a recently renovated bathroom ... the problem is, the new sub-floor is lower than the old sub-floor and toilet flange.
    The person who did this renovating removed the old sub-floor then put down a sheet of 3/8 wood underlay as the new sub-floor. By the looks of things, the original floor was a piece of plywood with underlay over that .... anyway, the new floor - which has already been tiled - is about 1/2 - 3/4" (at least) lower than the bottom of the existing/old toilet flange.
    This is the home of an elderly couple with little money ... their son did the bathroom renovation but isn't sure how to fix the toilet problem so they asked me - mistake number two. :-) I'm just a do-it-yourselfer who hasn't seen this problem before.
    I suspect there are simple solutions to this problem but it seemed like a good idea to tap the minds of people who really do know things, rather than ask a store employee who really doesn't.
    Your help is greatly appreciated - thank you.
    Dec 2007
    Can you supply us with a picture?
    What is the I.D of the pipe?
    Do you have access to the undeside of this floor either in a basement or in the ceiling of the floor below it?
    I could get a picture but probably not for a few days. It just looks like a newly laid floor with the flange sitting 1/2" or so above the tile, attached to the pipe of course.
    Not sure what you mean exactly but it's 4" ABS - pretty sure. I'm in Canada and I believe that is standard for toilet drains.
    No.
    Hope this helps. I thought maybe there was some kind of adaptor or something, or 'perhaps' (not sure) I could cut off the pipe under the flange and put a new one on?
    Thanks for any help.
    Dec 2007
    Okay it helps that you know what your talking about.
    4" gives us a few more options than 3"
    Pretty much all we need to know is if the flange is on the outside or, inside of the pipe. If it is on the outside you can trim the pipe to the proper height and install a new flange on the inside.
    If the flange is on the inside of the pipe you'll have to carefully cut break pry the old flange out of the pipe. I usually put a large hose clamp around the outside of the pipe to help avoid breaking it.
    Okay thanks ... I have a lot of experience under my belt but by no means do I consider myself an expert. This one stumped me a little. What you are suggesting is right along the lines of what I was thinking; I just wasn't sure if there was an 'easy out' that I didn't know about. Unfortunately I have to go to their house to examine things, but I will do that asap and see what I come up with.
    I really appreciate your help Redwood - thanks so much. It makes a big difference to hear it from someone else - especially someone more knowledgable than myself. I wish he'd just replaced the sub-floor up to the level of the flange, but what can you do?
    I'm still wide open for ideas if you or anyone thinks of any other tips/suggestions, but like I said, I appreciate this.
    Thanks again.
    Dec 2007
    One other thing that you would do well with is to find a flange that is not all plastic but has a stainless steel ring. http://www.oatey.com/Plumber/Shared/...eel+Rings.html
    If you need any more help get a pic to post! It will cut out a thousand words in your post! LOL
    Good luck with your project!
